Message 1 of 4
repurposing BT Home hub 2 as a wifi extender
Hi sorry if a stupid question but   when repurposing an old home hub what does this mean when you type in a new IP address? Make sure this is outside the addressing range of the main Hub, by default this is 192.168.1.64 -192.168.1.253.
Does the new IP address need to end any number below 64 or any number higher than 253?
3 REPLIES 3
Message 2 of 4
Re: repurposing BT Home hub 2 as a wifi extender
Easiest is stay below 64
Message 3 of 4
You can't go above 253. 254 is the main hub address and 255 is the broadcast address and is the highest address. Use anything between 1 and 63
Message 4 of 4
A comprehensive thread on repurposing a router as a wireless point https://www.avforums.com/threads/faq-using-two-routers-together-extending-wi-fi.1554662/
