Message 1 of 4
reversing REMOVE for a specific device
How can I re-insert an entry in Home > Advanced settings > after clicking REMOVE for a specific device
3 REPLIES 3
Message 2 of 4
Re: reversing REMOVE for a specific device
The device will just appear the next time it connects. It's just an information screen, it doesn't add or remove the devices, just the entry in the list. The list is totally rubbish and bears little relationship to reality in any case.
Message 3 of 4
Thanks for your reply but:
Other devices do reconnect if disconnected by other means, but this device (a printer) was explicitly REMOVEd and never reappears even after both the router and the printer were both turned off and back on again. The printer continues to work none-the-less.
Message 4 of 4
See my final sentence in my original reply.
