Message 1 of 3
tl-wa854re WiFi extender
Hi there,
Currently upgraded to BT smart hub 2 and notice since doing so (last provider EE) my WiFi extenders drop out every now ant then. Like they are being disconnected.
I have smart lights running off them and also cameras on the 2.4ghz signal they give, so only notice when they stop working.
Is there any setting I am missing on the router itself that is messing with anything?
Cheers all 👍
2 REPLIES 2
Message 2 of 3
Re: tl-wa854re WiFi extender
have you turned of smart setup
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
Message 3 of 3
Would this cause those issues? Cheers
