thedantheman
Message 1 of 5
trusted sites settings BT 4g minihub
I'm stuck with a 4g mini hub for the next week due to a fault in my area and can't find how to set up trusted websites settings?
4 REPLIES 4
thedantheman
Message 2 of 5
settings 4g mini hub
I'm using a 4g min hub as I'm a Halo customer who has a local broadband fault.
My question is, How do I change the settings for trusted sites? I'm being blocked from sites because  sites I visit regularly are not included on the list of the pre-set safe sites
RobbieMac
Moderator
Moderator
Message 3 of 5
Re: settings 4g mini hub
Hi @thedantheman
Thanks for your posts and welcome back!
Sorry to see you're having problems.  Take a look at this link and let me know how you get on:  Using the 4G Mini Hub for BT Halo customers
Post back and let me know how you get on.
Cheers,
Robbie
thedantheman
Message 4 of 5
Thanks Robbie, the instructions on the link were very poor indeed  butI phoned BT, after a 2-hour wait I got some help and I had to turn ON parental controls and then turn them off!!
BT couldn't make it more confusing if they tried
RobbieMac
Moderator
Moderator
Message 5 of 5
Hi @thedantheman
Thank you for posting back!
I'm sorry for the confusion.  I'm really glad to see that you managed to get everything sorted out.
Cheers,
Robbie
