stonerrock
Message 1 of 19
turning off wifi
I have turned off the wifi on my new smarthub 2 yet it is still the same, ie not wifi free, as showing from the readings on my RF meter. Can anyone explain why this is? thanks.
18 REPLIES 18
Keith_Beddoe
Message 2 of 19
Re: turning off wifi
Because it will still be transmitting BT Wifi/FON.
You can opt out, but it can take 28 days for it to be actioned.
If you do not want any wifi, then you would have to use a third party router which has a wifi on/off switch.
stonerrock
Message 3 of 19
Thnx. So if I leave it as it is (ie turned off) it goes off after 28 days? Crazy system! Why can't they simply design a router that goes from wifi to wifi free at the flick of a switch? Could you suggest a 'third party router ' I could use? Incidentally the readings Im getting on my RF meter from this new hub are not reassuring...
Keith_Beddoe
Message 4 of 19
Provided you are not on an ultrafast connection, then the TP Link W9970 (about £35), works just fine, and wifi can be turned off using a switch at the back, or via the web interface.
See this similar thread. https://community.bt.com/t5/Home-setup-Wi-Fi-network/Trying-to-opt-out-of-BT-wi-fi-to-prevent-my-BT-...
stonerrock
Message 5 of 19
Hey Keith
Many thanks for this info. Very good of you, I will look into this router. Why BT has to make it so hard for anyone to switch off wifi is strange.
licquorice
Message 6 of 19
It is because it is not just a question of switching off the WiFi signal from your hub but also preventing your access to the BT WiFi signal at hotspots worldwide. If you don't provide a signal, you can't expect to use it whilst out and about.
stonerrock
Message 7 of 19
Yes I can see that. But there must be others like me who dont want to use it whilst out and about. Surely BT could make it so it's simple to switch off entirely with the clear understanding you can't use it anywhere else. Seems a simple thing to ask for really. Perhaps BT believes everyone likes bathing in radiation for extended periods of time? Still, this is an old ludite speaking - I don't even use a smart phone and never will.
Keith_Beddoe
Message 8 of 19
As I have said, the only immediate guaranteed permanent solution, is to use a router which you can disable the wireless.
Even disabling BT Wifi, is not permanent. If the home hub is factory reset, either by the user or the helpdesk, it will be automatically re-enabled by default.
stonerrock
Message 9 of 19
Yes thanks Keith.  A new modem as per your recommendation is on order and - hopefully - should be here any day.
Keith_Beddoe
Message 10 of 19
If you have any problems then please post back.
You may like to look at these pages for reference.
http://communityhelp.ddns.net/hardware/TP_link/w9970/hhreplace.html
As well as the switch on the back, you can disable the wireless from the web interface as well.
