Message 11 of 19
Re: turning off wifi
Hi Keith
All wired up and it looked good to go. But there was no internet connection. When configuring the router (ie after logging in using admin as the username and p/w) , it asks for a further username and p/w. Would this be the passwords on the back of the new BT router? Thanks, Chris
Message 12 of 19
@stonerrock wrote:
Hi Keith
No, its this
Message 13 of 19
Thanks Keith, very much appreciated.
Message 14 of 19
Hi again
After a couple of months of happy use of the new modem, a problem has arisen. Today BT 'updated' us to its new fibre optic internet connection. Unfortunately the new tp-link modem now longer works. Reconnecting the BT hub has the internet reconnected, but with the same problem as I started with - I am no longer truly wifi free. Could you offer any advice as to why the new modem isn't working and what I could do? Thanks.
Message 15 of 19
Its not working because you have changed from ADSL to VDSL. Factory reset the router and set it up again, this time select BT VDSL if it doesn't auto detect. Username and password are as before.
Message 16 of 19
That is assuming that @stonerrock  is not on ultrafast broadband.
Message 17 of 19
This profile, assuming superfast broadband.
Message 18 of 19
Thanks for your help.
Message 19 of 19
Thanks for your help once again Keith. V much appreciated!
