andypandy1
Message 1 of 2
whole home
Can I use Ac2533 with Ac2600?
Which one is the best?
1 REPLY 1
NeilO
Moderator
Moderator
Message 2 of 2
Re: whole home
Hi @andypandy1 welcome to the community and thanks for posting. The different types of discs are not compatible with each other, and which variant to go for really depends on what you need them to do. If you use the selector tool on this link it will ask questions to help you decide which set up would be best suited for your home and requirements.
