Message 1 of 2
Have turned on 2 phase access to emails so need a passcode as well as password - how to disable?
1 REPLY 1
Message 2 of 2
Re: Have turned on 2 phase access to emails so need a passcode as well as password - how to disable?
You turn it off in the same way as you turned it on.
See link
https://www.bt.com/help/security/two-step-authentication/
