TheLatman
Message 21 of 28
Re: 12500+ broadband outtages in one hour
I'm down in Glasgow..... Blue light on router, connection status says connected, but no internet. Funnily enough the initial tweet has been deleted..... Typical
mrbenjamin
Newbie
Message 22 of 28
Down still in chelmsford essex. none of the phone numbers seem to work to ring them!
ChrisFWood
Message 23 of 28
Well that explains it then, great when you are working from home and on a conference call using VoIP.
It would have helped if there support number actually told you some more information about the issue as well.
ChrisFWood
Message 24 of 28
Stockport is back online.
Message 25 of 28
Posted on the forum main index page
Internet connection problems?
We’re investigating a problem which may be causing you intermittent or no access to the internet. Our engineers are aware of the issue and working hard to fix it so you don’t need to report the fault. We’ll have things back up and running as soon as possible but we’re sorry for any inconvenience caused.
Updated: 02/02/2016
shought
Message 26 of 28
Mines back up in Essex.
clayto
Message 27 of 28
Torbay, South Devon. Mine is OK now  ---  I could not access BT Cloud or the Forum for a while but BT email seemed OK. I had the TV on so got updates on what was happening.
Message 28 of 28
