margaret2000
Message 1 of 14
2nd router started disconnecting.
Hi we was issued a second router from bt because the 1st router was disconnecting around 20 times a day. at first the connection was good for 1 week but now the disconnections have returned and I’m now back in the same position. I don’t know if it’s a fault with the smart hub 6s or my connection to the local cab but this is seriously the worst connection we’ve ever had.
13 REPLIES 13
Keith_Beddoe
Message 2 of 14
Re: 2nd router started disconnecting.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
imjolly
Message 3 of 14
sounds more like a line problems than hub especially as it happens to 2 different hubs
are you using the test socket with a filter to see if that helps by eliminating your internal wiring and the master faceplate as causing problems
margaret2000
Message 4 of 14
hi I don’t have that type of mastersocket, I have the old style one,
Keith_Beddoe
Message 5 of 14
What does your master socket look like?
Master socket with one socket
Or
Master socket with two sockets
margaret2000
Message 6 of 14
Top row number 4,
Keith_Beddoe
Message 7 of 14
@margaret2000 wrote:
Top row number 4,
That is old. Provided that is the only socket in the house, and you have no extension wiring, then that is as good as the test socket.
If you have extension wiring, then that can be the cause of disconnects, even if there is no socket or phone on the end.
margaret2000
Message 8 of 14
I have that one in the front room and another one which is identical in my bedroom.
Keith_Beddoe
Message 9 of 14
Then you probably have "star" wiring, where all the extensions are teed into a terminal block.
Star wiring will have an adverse effect on connection speed and reliability.
They may possibly be connected at the back of the master socket, but without removing the cover, its not going to be possible to tell.
You can ask BT for an Engineer Home Improvement visit, but its not free.
They would fit a new filtered socket, but would  disconnect all of the extension wiring.
http://bt.custhelp.com/app/answers/detail/a_id/12439/~/engineer-charges
margaret2000
Message 10 of 14
Okay I’ll check how much it would cost, thank you so much for your time.
