Message 1 of 6
3 weeks no Internet.
Someone told me that I can cancel broadband service even though I'm under contract if the fault is not fixed within 7 days after fault reported.
I just want to check if it is correct information.
5 REPLIES 5
Message 2 of 6
Re: 3 weeks no Internet.
Not sure there’s anything to back that up. There’s a “right to exit” if you fall below the speeds you were promised and it can’t be fixed after 30 days, think a total loss of your service is a bit different however you would be compensated once it’s been sorted.
Message 3 of 6
Not true
If you have reported the fault to  BT Retail then they will arrange for openreach visit to fix the fault. Have you had a date for openreach visit
Message 4 of 6
I reported no connection( flashing orange light) fault 3 weeks ago through MY BT app. Got a phone call from an agent and told me that there's major outage so they can't send me an engineer.
when I checked service status through openreach there was no major outage with my postcode and phone number.
 Also there's a facebook group page for people live in my street. I asked if anybody experienced no internet connection issue. Apparently I'm the only person having the issue.
Frankly i dont believe there's major outage in my street. Because I know excactly when i lost internet connection. On that day I changed my ceiling light pendant. To do so, i had to shut down power for the house for safty. After changing ceiling light pendant, I turned the power back on. All my electric devices, fridge, lights came back on normal but i lost internet connection since then.
What a coincidence!!
I was given a new router but no joy.  I kept ringing BT and they just have been telling me the same. 'There's major outage. We cant send you an engineer. You just have to wait.'
I asked them if they can see any progress or updates from engineer who dealing with the 'major outage'. They said no.
I think i gave BT enough time to fix the fault but it seems that nobody is dealing with my issue.
What should i do now?
Message 5 of 6
What broadband do you have FTTC OR FTTP? what colour is light on hub?
If you have a calls package is there a dial tone on your landline?
Have you tried going to 'help' at top of forum page and then enter phone number to check any faults
Message 6 of 6
Thank you so much for your help. There's flashing orange light on the router. I don't have an analogue home phone so I couldn't check landline separately. I only have a digital phone. I tried help menu on the forum page as you said and chose landline instead of broadband. And it did let me book an engineer.
