kane982
Message 1 of 4
3rd Party Router Re-sync Question (VDSL2 FTTC)
Been looking everywhere for an answer to this but I cant find one, so hopefully someone here can help.
I've just replaced my Home Hub with an 8800NL R2 which is working perfectly, but I don't know how it handles re-syncing the line speed.  The BT routers automatically disconnect and change the line rate themselves according to DLM, but will this new router also do that?  Or will I have to manually re-connect the line every few weeks to see if the speed has changed?
I recently replaced the cable between my router and the master socket as well (the day before) getting the new router, so my speed's currently sitting at 25mb with a max rate of about 45-50mb on the line, so there's plenty of room for improvement, but I don't want to reset the connection too soon and risk making it worse.
Tags (3)
3 REPLIES 3
imjolly
Message 2 of 4
Re: 3rd Party Router Re-sync Question (VDSL2 FTTC)
You need to leave the router connected 24/7 with no resets. You need a stable connection before the DLM will make any changes to connection speed automatically
pippincp
Message 3 of 4
Your router will automatically adjust to any change without intervention from you. Leave it alone to do its job.
kane982
Message 4 of 4
Right, good to know.  Thanks everyone.  Line's been up 2 days so far with only a minuscule amount (<1%) of RS correctable errors so hopefully it'll speed up again in the next week or two.
