Message 1 of 8
500 - 900 upgrade, up speed still stuck at 72.2 to box
Making a fresh thread from comment here  https://community.bt.com/t5/BT-Fibre-broadband/Re-BT-Fibre-500-to-900-Upgrade-No-change-to-upload-sp...
Upgraded from 500 to 900, download is great reaching 1.2gbps through fast.com upload stuck at 66 max, 72.2 to the box
tap1 test through bt wholesale gives me 42.3 upload but the profiles are set at 957.76 down 115 up..
Tried powercycling ONT but still same 72.2 to the box and same ip address
if there’s any way you can refer this to openreach without an engineer having to come out to open a ticket that would be great
@JohnC2 I’ve tagged you as someone else said you sorted it for them, if any other mods come by could they please get in touch with you
7 REPLIES 7
Message 2 of 8
Re: 500 - 900 upgrade, up speed still stuck at 72.2 to box
Message 3 of 8
Hi @ballstorture and thanks for posting about your upload speed.
Sorry it's not what you would expect. How are you testing? Wireless or wired?
Cheers
David
Message 4 of 8
Currently 920 down 66 up.. bras profile says 957.76 down 115 up but the upload speed is stuck at 72.2 to the box, same as the 500 package
Message 5 of 8
Wired or wireless?
Cheers
David
Message 6 of 8
Cabled of course, wouldn’t get 900 on wifi
Message 7 of 8
@DavidM Problem solved.. had a fault ongoing and changed the appointment last night from Monday to today.. engineer came out, showed him similar posts to mine here and a comment regarding one of the mods sorting it, he made a call to OR, broke the connection and restarted it. Speeds now fine, you can mark as solved
Message 8 of 8
Hi @ballstorture,
Thank you for posting back to update the thread. I'm happy the engineer has been able to help.
Thanks,
Paddy
