topleya
Message 21 of 45
Re: 50Mbps on Fibre 2 - Since Late 2017
Sorry, working again.
Will check this evening.
I'm available all day tomorrow (Thurs 14) for a call.
Thank you
topleya
Message 22 of 45
Done some speed tests (wired directly into router)
Maximum speed is now 55u 18d.
So far a slight increase, but a long way off what I once received and what I know the line can offer.
imjolly
Message 23 of 45
are these speeds connection speeds or download speeds?
can you post up to date router stats showing connection information
topleya
Message 24 of 45
pippincp
Sage
Message 25 of 45
Looks like you've had a DLM reset so it will take a few days to settle. Which exchange and cab are you on?
topleya
Message 26 of 45
Test in 2017Test in 2017Test TodayTest TodayTest TodayTest TodayTest TodayTest Today
topleya
Message 27 of 45
"Exchange ALDERSHOT is served by Cabinet 95"
NeilO
Moderator
Moderator
Message 28 of 45
Hi @topleya we'll need to give it a few more days to settle after the reset and if no further improvement by Monday I may need to organise a visit to see if an engineer can boost your speed any further.
topleya
Message 29 of 45
Ok, no problems.
I'll monitor for the week and check back.
Thank you
pippincp
Sage
Message 30 of 45
The reset will have disabled G.INP. It should kick back in over the next few days and give you a speed lift.
