imjolly
Message 11 of 45
Re: 50Mbps on Fibre 2 - Since Late 2017
I have asked a mod for some help checking to see if inadvertently you have benn moved to superfast 1 for down speed.  They will post here
pippincp
Sage
Message 12 of 45
I have an idea it could be DLM stuck and a reset may correct it. Whatever it is the mods will get to the bottom of it.
topleya
Message 13 of 45
I learned of DLM today and this could potentially be it.
As I said before, I have a lot of issues with HomeHubs dying on me, before they died they were crashing and rebooting a lot on their own.
I spot with support earlier today and they are send an engineer to the exchange within 48hrs.
They have also forwarded my case to complaints due to me having restricted speeds for so long and paying full price.
Fingers crossed, all should be resolved soon.
pippincp
Sage
Message 14 of 45
Pointless sending an engineer to the exchange. Wait for a mod to get back to you.
topleya
Message 15 of 45
I agree with you, I believe it's one of the above reasons that's causing it.
Can't imagine this being an exchange fault that would cap a download at 50Mbps all the time for the over a year.
imjolly
Message 16 of 45
Any restriction is on your connection speed at 55mb not on your download speed
JohnC2
Moderator
Moderator
Message 17 of 45
Hi @topleya  sorry you are not getting the speed you expected from your broadband.  I've sent you a Private message explaining how you can contact the forum moderation team and we will be happy to look into this further for you.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
John
NeilO
Moderator
Moderator
Message 18 of 45
Hi @topleyathanks for sending in your details. I called there but missed you, I've taken over management of the fault and complaint on your account and have raised a case with our suppliers BT Wholesale to look at your broadband speed. I hope to have further updates for you tomorrow and will follow up with you then.
topleya
Message 19 of 45
Thank you Neil.
I received your voicemail. My apologies I am in work so unable to answer.
NeilO
Moderator
Moderator
Message 20 of 45
@topleya I called there but missed you, can you check your speed? My tests are showing a good improvement.
