Message 11 of 12
Re: 6th engineer visit and bb still not fixed
Have they identified if it’s the Router losing sync with the DSLAM or if it’s the PPPoE Session restarting?
Community Manager
Community Manager
Message 12 of 12
Hi @Rossjohn123 good speaking with you there.
The work that the last engineer completed and then replacing your Hub seem to have fixed the fault, however please do post back if there's anything else we can help with.
Community ModeratorStephanie
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
