Message 1 of 26
7mbs on fibre. line tests always say ok?
I have just moved to BT from Talktalk. Sold 18-24mbs with lowest guaranteed 13mbs.
I live in a close with 19 houses and ours is the lowest by far. I know its our line to the house but openreach will do everything they can to not spend money replacing lines.
So i have checked some house in the close.
N05 has 12mbs on standard copper and works for BT
N019 opposite has 22mbs on fibre
N014 next door has 24mbs on fibre
N015 my house has had 4 visits in 2 years and a new test socket fitted by openreach and 7mbs on fibre.
i have an enginner booked for 15th december but i doubt anything will come of it. Line tests do not find faults as i have gone from 1mbs to 24mbs at my last house with a new line installed. while talktalk insisted the line was fine.
p.s, I know people rant over speeds. 20-100mbs you will not notice,but when you have 7mbs on fibre and your kids put netflix on its game over man!
25 REPLIES 25
Message 2 of 26
Re: 7mbs on fibre. line tests always say ok?
post the stats from your router
enter your phone number and post results  remember delete number  http://dslchecker.bt.com/adsl/adslchecker.welcome
Message 3 of 26
Message 4 of 26
Sage
Message 5 of 26
Wrong stats page.
If you are using the BT Smart hub you can get your connection stats by, Opening a new web browser on your connected device and type 192.168.1.254 or bthomehub.home into the address bar. This will open the Hub Manager.  Click Advanced Settings’ and then ‘Technical log’.
If HH5 then Troubleshooting/Helpdesk.
Have you checked for noise on your line? 17070 option 2. Any noise report a line fault on 151 without mentioning broadband.
Message 6 of 26
When you are posting the stats can you include the Modulation figure.
Message 7 of 26
Message 8 of 26
not sure where to find mod figure
Message 9 of 26
If you go to the stats as requested in message 5 its near the foot of the stats and should look like Modulation: G_993_2_ANNEX_B
Message 10 of 26
not in technical logs
