Message 1 of 6
ADSL filter
I have recently got digital voice.  My Smart Hub still has an ADSL filter, but is this still necessary or can I now plug the hub straight into master socket with no filter?
5 REPLIES 5
Message 2 of 6
Re: ADSL filter
The filter is no longer needed, its purpose was to stop the broadband signal reaching the analogue phone.
Message 3 of 6
Re: ADSL filter
Thank you!
Message 4 of 6
Re: ADSL filter
The router cable will not fit into the master socket as it is the wrong size.  Can I use the ADSL filter as an adapter or should I get another sort of adapter?
Message 5 of 6
Re: ADSL filter
Either, or get an Rj11 to BT431 cable
Message 6 of 6
Re: ADSL filter
Thank you!
