Matti-coops
Message 1 of 28
ADSL2+ to VDSL has slowed my speed down dramatically- will it get better?
Hi,
my line has finaly been transfered from ADSL2+ to VDSL2.
I had a predicted speed of about 10Mbs- On ADSL 2+ I was getting about 6Mbs-
I am about 2.5km from the cabinet.
My download speed has dropped to 4.4Mbs according to my BT smart hub
Is it likely my speed will improve or am I best downgrading to ASDL2+ again??
27 REPLIES 27
Message 2 of 28
Re: ADSL2+ to VDSL has slowed my speed down dramatically- will it get better?
At that distance from the cabinet, VDSL may not be any better, and its likely to disconnect more often. ADSL2+ is generally more stable and of consistent speed.
The actual cable distance may be further than that, as the cables do not run direct.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Matti-coops
Message 3 of 28
Thanks for the prompt reply-
Here are my stats:
 Exchange CROGLIN is served by Cabinet 3
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in JumperObserved SpeedsVDSLADSLOther Offerings
Availability Date
Premise environmentStatus
VDSL Range A (Clean)10.95.51.20.84.1Available----
VDSL Range B (Impacted)10.45.21.20.53.8Available----
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 1--1 to 3.5Available--Yes
WBC ADSL 2+ Annex MUp to 1Up to 0.51 to 3.5Available--Yes
ADSL MaxUp to 1--0.75 to 2.5Available----
Fixed Rate0.5----Available----
Max Observed Downstream Speed (Mbps)--6.16
Max Upstream Observed Speed (Mbps)--0.97
Observed Date--2019-02-25
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapU
VRIN
NTEFaceplateP
Last Test Date26-02-2019
Message 4 of 28
I can see the figure for ADSL2+
Max Observed Downstream Speed (Mbps) -- 6.16
That was better than expected, so your line performs better at ADSL2+ frequencies, that it does on VDSL.
As the handback speed on VDSL is only 4.1Mbs, it would indicate that Openreach do not expect a lot from that service.
My personal opinion would be to revert back to ADSL2+, as you are likely to get better long term stability, especially if crosstalk increases as more people get connected to the cabinet.
Techwizz
Message 5 of 28
I agree with @Keith_Beddoe, you would have a better quality of service on ADSL2+.
Matti-coops
Message 6 of 28
Thanks. I will wait a few days to see if it improves at all. If not how do I revert back to ASDL2+?
Techwizz
Message 7 of 28
Just contact BT and explain that you are getting slower speeds on VDSL, they may not be inclined to that (due to the estimates being higher on VDSL), but try to enforce that you're receiving a slower speed. If you get stuck, let us know, and then hopefully a mod can investigate.
Matti-coops
Message 8 of 28
Matti-coops
Message 9 of 28
Since my line was swapped to the VDSL connection from the ADSL2+ connection it has developed a lot of "static" particularly when I first pick up the line it then usually settles after a few seconds. - This occurs even if I plug directly into the master socket.
It is intermittent- At times it is bad enough not make it difficult to hear what people are saying on the phone- at other times it does not seem to be a problem at all…
This has only started happening again since line swapped over- Could something have happened to how the line is connected in the cabinet / exchange when being swapped over??
Message 10 of 28
Probably a bad termination in the cabinet.
Just report it as a noisy phone line.
