hifistud
Message 1 of 40
ASUS DSL-AC68U AC1900 - anyone tried this on infinity?
I am finally fed up with constant reboots and disconnects and not being able to turn remote configuration off, so it's time for a new VDSL2 router. Has anyone tried the ASUS DSL-AC68U AC1900?
39 REPLIES 39
shirts
Recognised Expert
Message 2 of 40
Re: ASUS DSL-AC68U AC1900 - anyone tried this on infinity?
That is what I am using, with an unlocked HG612. Works well.......Smiley Wink
If you found this post helpful, then please click the star on the left, after all, I'm only trying to help........Smiley Wink
Sage
Sage
Message 3 of 40
Why not go the easy route and purchace a modem from a well known auction site which users report has solved that problem? Just use the HH5 as a dumb router.
hifistud
Message 4 of 40
Wall space, really. Have grown used to a one-box solution and would prefer that, I think. SWMBO also has input in terms of footprint!
shirts
Recognised Expert
Message 5 of 40
AC68U does not contain a modem, so you will still need a seperate modem........
Distinguished Guru
Message 6 of 40
Yes it does. The RT-AC68U doesn't.
If not, I'll try again 🙂
shirts
Recognised Expert
Message 7 of 40
Oops....Apologies.....my mistake. I have the RT version. Out of interest, had a look for the DSL version. Seems to be primarily used in Australia and the far east.......
hifistud
Message 8 of 40
Yeah - like ben's teeth in UK, worst luck. Looks good, too.
shirts
Recognised Expert
Message 9 of 40
Ha, ha, ha, poor old ben........did you mean "hen's teeth" ? Smiley Very Happy
AndyCr15
Message 10 of 40
Could someone be more specific about the cheapest alternative for the HH5?  Using the well known auction site is fine...  🙂
