SWFC-JON
Message 11 of 16
Re: ASUS DSL AC68U - CORRECT SETTINGS
Sorted mate!  Thanks all!
DoctorRobert44
Message 12 of 16
Hello to anyone you has a clear answer to my problem. I’ve been trying for 2 days to get my ASUS DSL-AC68U router to work on BT!
I’ve followed countless guides online and input all the correct details so many times now and every time I click okay it gets to the home screen and says ‘internet status: disconnected’. I’m literally pulling my hair out! All the correct lights are flashing in the router but it’s just not allowing the internet to connect for some reason.
Please can someone shed some light on this!!
licquorice
Message 13 of 16
What are the 'correct' details that you have entered? Are you on Infinity (VDSL) or standard broadband (ADSL)?
TimCurtis
Recognised Expert
Message 14 of 16
@DoctorRobert44
Please do as @licquorice has requested.
What username have you used as this is often a common mistake?
JEZ222
Message 15 of 16
Non-standard G.vector (G.993.5). had to be disabled for me or connection broke
Im on BT's Fibre 2 plan
My ping times to London servers aren't too bad anyway  (im about 20miles away)- they range from 8 to 15ms
licquorice
Message 16 of 16
Useful information but you are replying to a 2 year old post.
