Gregg1234
Message 1 of 10
Activation date
The engineer didn't show up or tell us they weren't coming. Apparently we now have to wait another week. We have a grey bt box on the wall so we should only need them to connect it from outside. What is the issue with this?
9 REPLIES 9
Keith_Beddoe
Message 2 of 10
Re: Activation date
@Gregg1234
Is this a new build property?
Gregg1234
Message 3 of 10
Re: Activation date
Hello. Yes it is we should have everything set up and there are wires going into the box. We even have a bt manhole outside our house. The builder says he had everything installed so it should just be the connecting.
Keith_Beddoe
Message 4 of 10
Re: Activation date
So you do not have any phone sockets inside?
Gregg1234
Message 5 of 10
Re: Activation date
Yes we do. Our hub arrived but the wires from the grey box just need connecting I think.
Keith_Beddoe
Message 6 of 10
Re: Activation date
Provided that Openreach do not have to enter your property, then it should be no problem.
Is there a master socket already fitted, it would look like one of these.
Gregg1234
Message 7 of 10
Re: Activation date
Yes we have several of them. When I rang bt they said the engineer has to do a survey and that wont be for another week. The guy from virgin said bt weren't going to be doing any work until june.
Gregg1234
Message 8 of 10
Re: Activation date
There is an open reach one that says master socket on it
Keith_Beddoe
Message 9 of 10
Re: Activation date
Then that should be the one that has been cabled back to the box outside, by the builders.
Provided the box has the external cable internally connected to it, then it would just need connecting outside, by Openreach.
Gregg1234
Message 10 of 10
Re: Activation date
Thanks for your help
