Message 1 of 6
Actual sync lower than it shows in the logs
Hello,
Had BT FTTC activated yesterday, the sync speed in the logs seems to be higher than the actual sync speed, 47.8mb vs 41mb. It's on a standard Smart Hub. Would anyone know why this is? I'd post a screenshot but i can't see an option here!
Cheers,
Ben
5 REPLIES 5
Message 2 of 6
Re: Actual sync lower than it shows in the logs
Sage
Message 3 of 6
Post the information from the technical log.
Message 4 of 6
I have, it should be the first screenshot 🙂
Message 5 of 6
The logging doesn't seem to have initialised properly, it is still showing boot up date of 1st Jan. You could try a factory reset by pressing the recessed pin until the lights flash.
Message 6 of 6
I will do that when DLM has settled down, only recently had a line problem that has only (i hope) been resolved.
