Hello,
Had BT FTTC activated yesterday, the sync speed in the logs seems to be higher than the actual sync speed, 47.8mb vs 41mb. It's on a standard Smart Hub. Would anyone know why this is? I'd post a screenshot but i can't see an option here!
Cheers,
Ben
I have, it should be the first screenshot 🙂
The logging doesn't seem to have initialised properly, it is still showing boot up date of 1st Jan. You could try a factory reset by pressing the recessed pin until the lights flash.
I will do that when DLM has settled down, only recently had a line problem that has only (i hope) been resolved.
