mattricks
Message 11 of 30
Re: Address fustrations
Thank you for the advice, much appreciated.
imjolly
Message 12 of 30
you need your address correct on royal database and the same address registered on the openreach database.  The checker is based on openreach database and until that shows FTTP available you are going to have problems with all ISP apart from virgin
mattricks
Message 13 of 30
Brilliant! just Brilliant....., The whole thing has been one big frustrating mess....no one has mentioned Royal mail until today...I've been trying for weeks, just a complete joke, now ill start talking to Royal mail. I just hope they are faster than bt at sorting this.
imjolly
Message 14 of 30
It's not BT Retail as you say your address is correct on their records and you need that to tie in with royal mail and also openreach.  if you can get royal mail correct same as BT Retail then you can ask BT to raise and ORDI request with openreach to get their database corrected
once all done that should help you with your order - all starts with royal mail
mattricks
Message 15 of 30
Thanks for the information. I can't believe I'm just finding out about this Royal mail problem today.
pippincp
Sage
Message 16 of 30
To check if address is registered with Royal Mail just go HERE.
mattricks
Message 17 of 30
Well, That's 20 minutes on hold with Royal mail. not a good start. Cant believe this....never had something be so frustrating. I'm ******* done, this has all been a complete waste of time! what the hell will it take to sort this out. Outrageous!
imjolly
Message 18 of 30
as soon as you get the royal mail database to be identical to the BT Retail address then post back and mods will be able to place ORDI request with openreach
pippincp
Sage
Message 19 of 30
Did you check the Royal Mail site before phoning?
mattricks
Message 20 of 30
Yes I did. It did not have my address on their postcode checker.
I have completed the online form but their is no indication to how long it might take.
I have tried to email them but it seems impossible to find any email address that is not blocked.
If anyone has any suggestions on how to get hold of them I would appreciate it as I work in the day and get home at 6....when royal mail phone lines close.
