jonny321321
Message 1 of 3
Am I behind a CGNAT and if so how can I disable it?
I've been having issues getting port forwarding to work. Even placing my device in the DMZ reports all ports bar 2 as closed. I'm on BT Infinity 2 using ipv4. I'm not behind a double NAT either.
Reading some older forum threads they said the moderators could disable it. I'd appreciate that!
Thanks.
2 REPLIES 2
licquorice
Message 2 of 3
Re: Am I behind a CGNAT and if so how can I disable it?
I very much doubt if you are behind CGNAT, however, it is easy to check. Go to https://www.whatismyip.com/ and see what your public address is and compare it with what your hub indicates your public IP address is. If they are both the same you aren't CGNATTED.
jonny321321
Message 3 of 3
According to my router homepage the IP addresses are the same. Thanks!
