Expert
Message 1 of 21
Ambient temp affects noise margin
I normally get 50Mb at 3.0 dB but when there is a 'heatwave' I end up with 45Mb at 3.0dB
So what is there outside, I guess, that gets hot, expands and increases noise?
I am 'off a pole' btw.
No disconnect, the DLM 'sees' the noise margin dropping and starts dropping the speed.
After the temp goes back to normal the speed increases.
David
20 REPLIES 20
Message 2 of 21
Re: Ambient temp affects noise margin
Your connection speed cannot drop unless the router drops internet connection but the max attainable will fluctuate as your noise margin changes. My noise margin moves +/- 0.2db depending on weather conditions with corresponding decreases/increases in max attainable. My connection speed remains constant though
Expert
Message 3 of 21
+/- 0.2db, if only!SNR 23_4.JPG
As you can see the max is lower than the actual.
Message 4 of 21
you have G.INP active on your line hence the lower noise margin - normal about 3db
Expert
Message 5 of 21
I understand about G.INP etc
Message 6 of 21
sorry  I seem to be missing something
are you saying that your data rate not Max data rate is changing as your noise margin changes but you dsl uptime is not resetting?
Expert
Message 7 of 21
I see what you are getting at now.
1. The max data rate does not change.
2. The noise margin does change.
3. The actual data rate does change.
4. The dsl uptime does reset as can be seen by the last photo.
It has always seemed weird that the max data can be lower than the actual. This has been 'proved' by speed tests.
Expert
Message 8 of 21
There is one thing I hesitated to ask - perhaps the HH6 is faulty
The stats are strange after all and whilst I do not know how it 'all' works perhaps the hub does not like the heat?
The other issue is the cabinet. The data below have been like this since 2013 and do not reflect reality.Cab.JPG
 The actual have been much higher for some years. A boost eng' commented that the cab' would have to be sorted out one day.
Message 9 of 21
@DavidCo wrote:It has always seemed weird that the max data can be lower than the actual. This has been 'proved' by speed tests.
Not really, its quite normal, it depends what you noise margin was at sync time.
Mine is at the moment
Data rate:8.539 Mbps / 65.094 Mbps
Maximum data rate:8.539 Mbps / 64.813 Mbps
Expert
Message 10 of 21
Beats me then because I know that when the ambient temp' drops back to 'normal' my speed will gradually increase back to what it was!
