Recognised Expert
Message 21 of 21
Re: Ambient temp affects noise margin
@DavidCowrote:
I've given the darn thing time settle down and am puzzled!
My down stream sync is now 44.87. The noise margin fluctuates between 2.5/4.5 - Why!
My IP profile is now 41.23 (BT wholesale)The BTW speed test is giving incorrect results and is not to be trusted.
The above gives a ratio of what?
OR have been installing some new gear just up the road for a new estate (small) That area had a cabinet (Cu)
They have run fibre from the FTTC area that I'm off across the road (away from me)
Straight to a new 'Combi', then they have added a 'Pod' to the old cabinet (Cu)
Could I be looking at a capacity issue?
