I have replaced the Smart hub with TP Link Archer VR900 router and I have the option to choose between Annex A and B, which one is better and what is the difference?
modulation is 993.2 annex b
from memory I just used quick setup said BT and enter username and password and router did the rest
So I should use the TP Link quick setup and let the router select the Annex type instead?
Also, does Annex type affect the line speed?
i would use quick setup and select bt vdsl and let route do the rest
