Message 11 of 17
Re: Another speed reduced after upgrade from infinity 1 to 2
can you run btspeedtester and when first test completes then run diagnostic test and post results please  should be done with wired connection
btspeedtester
oldeng99
Message 12 of 17
oldeng99
Message 13 of 17
Message 14 of 17
can I check that you are now using the test socket indicated by the black arrow and the rj11 cable form modem is conencted to the filter in the test socket
oldeng99
Message 15 of 17
Having removed all the inhouse wiring completely I was using the normal outlet with all wifi and power line plugs turned off or isolated.
I have now managed to find an old style filter and fitted this to the internal test socket and the results are as follows.
Speed test DL 29.04  UL 6.98
Diagnostics
DL 29 .04  IP profile 29.04
UL 6.98  IP profile 20 Meg.
Its a bit fiddly to get pictures so hope the information is OK.
FYI the phone is not plugged into the filter and the filter is an older BT filter as used on the original ADSL pre Fibre to the cabinet.
RU ex BT ?
oldeng99
Message 16 of 17
ping 43 forgot sorry
Message 17 of 17
if you are now using test socket with filter (old adsl is fine) and speed still below estimated speed then you need to get engineer visit and see if they can get you speed up within estimate
I am not and have never worked for BT/Openreach
