highpriest
Message 1 of 6
Any DrayTek Vigor 130 users here?
I'm looking to replace my HomeHub 5B with a DrayTek Vigor 130 and a homebrew router. Anyone here use a similar combination on their Infinity connection?
I'm after some feedback on the modem itself, and specifically around how it performs with BT Infinity connections. I have the 80/20 package.
Is there a risk of missing out on new technologies (Vectoring, G.Fast, G.Inp, whatever) if I use a third-party modem?
Thanks!
5 REPLIES 5
Message 2 of 6
Re: Any DrayTek Vigor 130 users here?
Interestingly the Vigor 130 appears to support vectoring bit not G.Inp (G998.4)
Protocol Support:
  • ITU-T G.993.1 VDSL
  • ITU-T G.993.2 VDSL2
  • ITU-T G.997.1
  • VDSL Annex A, Annex C, Annex M
  • VDSL Profiles: 8a, 8b, 8c, 8d, 12a, 12b, 17a
  • VDSL Vectoring
  • OLR, UPBO, DBPO, US0
  • ANSI T1.413 Issue 2
  • ITU-T G.992.1 G.dmt (ADSL)
  • ITU-T G.992.2 G.lite
  • ITU-T G.992.3 ADSL2
  • ITU-T G.992.5 ADSL2+
  • ADSL Annex L (READSL)
  • ADSL Annex M
  • PPPoA-PPPoE or PPPoE-PPPoE Bridging (WAN to LAN)
  • RFC-2684 / RFC-1483
highpriest
Message 3 of 6
Looks like it is supported with a newer firmware release.
http://forum.kitz.co.uk/index.php?topic=15504.0
Cheers
highpriest
Message 4 of 6
Bump.
wojtas29
Newbie
Message 5 of 6
hi
im user of vigor 130
i have a question regarding firmware.
I see on draytek website  newer fw as my one but there is few versions of this firmware
modem 1
modem 2
etc
etc
 i have no idea which i can use
im bt infinity user
Any idea?
highpriest
Message 6 of 6
Really? I see only one firmware available for download here: http://www.draytek.co.uk/support/downloads/vigor-130
Are you looking on their FTP site?
3.8.1BT appears to be the latest firmware for the device. There are two files in the bundle; they are identical but the one with the ".rst" extension will reset your device to factory default settings.
Firmware File Types
The ZIP file contains the firmware with two different file extensions, .ALL and .RST. The firmware is identical but the RST file contains factory default settings. If you install the ALL file, your modem will retain all existing settings. If you use the RST file, all settings will be wiped from your modem.
HTH.
PS: I no longer use this modem.
