Message 1 of 13
Any idea what this means..
Hi - Just been on the BT DSL Checker & noticed this
 Any idea what it means?
12 REPLIES 12
licquorice
Message 2 of 13
Re: Any idea what this means..
Probably ISDN or DACS, but as you have had ADSL working already it seems a bit odd.
Did the upgrade to FTTC happen on the 22nd as planned?
albertj
Recognised Expert
Message 3 of 13
Do you have broadband at the location you have entered?
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Message 4 of 13
Hi - Yes I'm on faster fibre as of the 22nd. I don't think I've been on the site since I upgraded to FTTC. It wasn't on there last time I looked & that was probably a couple of weeks back..
licquorice
Message 5 of 13
Odd, but obviously hasn't prevented anything happening.
Message 6 of 13
@MattS - This is still showing on the DSL Checker. It's now a good 3 months since you said you would contact OR to have it removed..
It's not a problem now but might be in the future should I choose to move away from BT. Thanks..
PaddyB
Moderator
Moderator
Message 7 of 13
Hi @8062282,
Thank you for posting @MattS isn't in the office today, he is back in tomorrow and will follow up with you then.
PaddyB
Message 8 of 13
OK, thanks..
Message 9 of 13
Hi - Any new's please?
Message 10 of 13
Hi @MattS - Any news on when this will get removed please?
