Nealjane
Message 1 of 3
Anyone help with when my exchange will be upgraded for fibre ? Please?/
Ok so, I work from home and I’ve decided broadband just isn’t cutting it anymore. Thought it would be easy to upgrade to fibre...!!!! Was I wrong....
so my exchange (CABINET) is full, and been told I just need to keep checking....
prev used to be able to find out when exchanges were being upgraded, but no luck - anyone help me?
exchange is Caldy , west kirby, cabinet 1 p1..ch486dy
Fibre Street Cabinet 1: P1
FTTC Available from 21st October 2014
Phase 11b 2013-2014
Any help would be v much appreciated..!
2 REPLIES 2
Message 2 of 3
Re: Anyone help with when my exchange will be upgraded for fibre ? Please?/
Welcome to this BT Retail user forum @Nealjane
Only Openreach would know that.
Its the cabinet that will be full, not the exchange.
Message 3 of 3
Its not your exchange that is full it will be your cabinet. All you can do is keep checking.  If the cabinet is sub-equipped with cards it might only be a short while before extra cards are fitted. If the cabinet is fully populated, it may be a very long time or never before a second cabinet is installed. You can only hope that somebody ceases their service and you can dive in and nab their slot.
