shirts
Recognised Expert
Message 11 of 34
Re: Anyway to speak to someone on helpdesk that actually knows about fibre?
It is possible that as more and more customers get connected to your cabinet, the problem of crosstalk increases. Four months ago, I had a possible download speed of 80 which has now dropped to 74.5 Smiley Sad
If you found this post helpful, then please click the star on the left, after all, I'm only trying to help........Smiley Wink
phillarkin
Message 12 of 34
i can understand crosstalk being an issue but wouldn't max data rate go down if that was an issue? Also would that not affect everyone on the cabinet and not just me?
phillarkin
Message 13 of 34
Oh and the promised call back from a manager hasn't happened- what a surprise!
Message 14 of 34
the max date rate does vary slightly constantly throughout the day
shirts
Recognised Expert
Message 15 of 34
That depends on how the cables are set out, and exactly where the crosstalk is causing the problem.....
Distinguished Guru
Message 16 of 34
Yeah, looks like DLM has capped your line due to the disconnections.
If not, I'll try again 🙂
phillarkin
Message 17 of 34
So work out what's happening with the disconnections and get them stopped and then sit out DLM or will bt reset the DLM for me ?
Distinguished Guru
Message 18 of 34
If DLM gets reset but the disconnections continue then you will end up back in the same position. You need the disconnections to stop, then DLM will uncap the line automatically.
phillarkin
Message 19 of 34
OK will get back on to BT when I can and sort the disconnections and go from there. I will report. Thanks to you all.
phillarkin
Message 20 of 34
Spoken to a "manager" this morning who appears to be the same as his staff and doesn't know the difference between sync and throughput. Also wasn't very willing to find out whats causing the disconnections or non response of the box!
I wish BT would employ people know the product they support.
