FatAndAngry
Message 1 of 10
Appalling evening speeds
Hi all,
I recently came across to BT Broadband from IDNet and have been seeing huge performance issues in the evenings.  I'm currrently synced at 70/20 and daytime speed tests on both BTW and speedtest.net show good performance.
The evenings are a different story however.  I have seen speeds around 15mb down, and certainly no higher than 20mb.  I opted to not use the Smart hub, and continue to use my own equipment (Asus, good quality).
Any suggestions please?   I'm really disappointed so far.
9 REPLIES 9
Moderator
Moderator
Message 2 of 10
Re: Appalling evening speeds
Hi @FatAndAngry
Thanks for your post and welcome!
Sorry to see you're having problems with your broadband speed in the evenings.  Can you complete >> this speed test << in the evenings when you feel it's performing slowly?
Also, please post your >> Router Stats << for the benefit of the community.  If you could also reply confirming what exchange you're connected to I can check for any known issues.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
FatAndAngry
Message 3 of 10
Hi Robbie,
I have already completed several of those speed tests in anticipation of you asking.
As for router stats, I am using a Netgear DM200 in modem only mode, and there are no stats available.
Moderator
Moderator
Message 4 of 10
@FatAndAngry what exchange are you connected to? I'll check the Wholesale congestion report and see if there are any known issues.
Community ModeratorNeilO
Kudos”Kudos”
FatAndAngry
Message 5 of 10
Great Yarmouth EAGYT
Message 6 of 10
As we are in peak time it would be helpful to post btspeedtester diagnostic results highlighting your problem. Please use IE/Edge and Ethernet connection. Other browsers giving varying results
Moderator
Moderator
Message 7 of 10
@FatAndAngry sorry about the delay getting back to you, there is an know congestion problem with one of the SVLAN's on the Great Yarmouth exchange that's affecting peak time speeds. I'm really sorry about the inconvenience caused by this and can confirm that BT Wholesale have a plan in place to have this fixed with an estimated repair date of 25/05/18.
Kudos”Kudos”
FatAndAngry
Message 8 of 10
Thanks, this is great news
Moderator
Moderator
Message 9 of 10
@FatAndAngry No problem, can you post back and let us know if you see an improvement next weekend?
Kudos”Kudos”
FatAndAngry
Message 10 of 10
Hi All,
Peak time speeds are definitely greatly improved.  Seeing consistent download speeds of 60Meg + this evening.  Still a bit impacted but certainly not 15 Meg as before.  Will continue to monitor and update if any change.
