Message 1 of 2
Archer AX50 router cant connect to internet
Hi all,
Have just had FTTP fitted with BT and want to use my Archer AX50 router to get an improved signal. I follow the TP Link app but it keeps saying connected without internet. Does the FTTP have a modem fitted or do I need to use the  Smarthub as a connection which I dont want to do?. What am I doing wrong if anything?
Tags (3)
1 REPLY 1
Message 2 of 2
Re: Archer AX50 router cant connect to internet
If you have FTTP, the ONT is the modem. You simply need to enter the  PPPoE username [email protected] and password BT
