fregrin
Message 1 of 16
Asus Dsl-ac68u stats check stability issues
Hello,
Had various issues with
speed and sync on HH5..anyway engineer coming soon,but I got this new router. Can someone please look at these stats and confirm to me they are OK.
DSL Firmware Version DSL Driver Version DSL Link Status DSL Uptime DSL modulation ANNEX Mode SNR Down SNR Up Line Attenuation Down Line Attenuation Up Path Mode Data Rate Down Data Rate Up MAX Rate Down MAX Rate Up POWER Down POWER Up CRC Down CRC Up
1.0.2.4
FwVer:5.5.1.128_B_A60901 HwVer:T14.F7_0.1
up
0 days 0 hours 6 minutes 31 seconds
ITU G.993.2(VDSL2)
ANNEX_B
4.9 dB
5.9 dB
5.9 dB
2.5 dB
Interleaved
70162 kbps
18579 kbps
103984
23798
13.7 dbm
-2.5 dbm
0
0
15 REPLIES 15
fregrin
Message 2 of 16
Re: Asus Dsl-ac68u stats check stability issues
scuderia92
Message 3 of 16
What are your dsl settings?
fregrin
Message 4 of 16
scuderia92
Message 5 of 16
I think those stats look good I would just leave it on now for a couple of weeks. I had similar stats but nothing changed so I changed it all back to defaults and have now promised to leave it all.
How long have you been interleaved for ??
fregrin
Message 6 of 16
Over week,but I made different changes to try get stable connection and each time make change it reboots.
TimCurtis
Recognised Expert
Message 7 of 16
I'd get the latest firmware and disable Stability Adjustment & TX Power control.
fregrin
Message 8 of 16
I have latest firmware..as far am aware 3.0.0.4.378_5007-g32566cc
Also if i disable those settings (Stability Adjustment & TX Power control), Data rate down drops a lot and i loose sync (connection thingy) for few seconds to a minute quite often.
If this is not latest firmware, please advise with a link.
Regards...
scuderia92
Message 9 of 16
Go onto the router via telnet and see the stats on there.
Also @TimCurtis with DLM being in effect when the line goes back to fastpath and improves will the router reset itself or are we best restarting it and seeing if any improvement is made after a few days ???
TimCurtis
Recognised Expert
Message 10 of 16
The latest DSL driver version is 5.5.1.128_B_A60901 HwVer:T14.F7_0.2 on mine whereas yours is 5.5.1.128_B_A60901 HwVer:T14.F7_0.1 although on the Asus website there is only 1 version so not sure why yours & mine should differ.
I'm far from an expert on these matters but I doubt that an SNR Down of < 6dB or the -2.5dbm for power up is good. My power up is 6.5dbm.
With DLM in effect continous connection really is required for the stats to improve. DLM will remake the connection if it changes anything so leave things alone, too many reboots will result in DLM thinking there is instability and drop the speeds.
