Message 1 of 4
At a loss
So since April my broadband speed is been up and down, one min it’s 50meg and then 37 and then 29 and 32 it’s all over the place.
this started in April and we have had 7 engineers out,
1st engineer replacement Socket and phone line
2nd engineer, noise on the line and fault
3rd engineer said the issue is at top of the pole (nothing done)
4th engineer, changed wires and cleaned something at the box
5th engineer, Said issue again at pole and he replaced something
6th engineer, again issue at the pole and he replaced something But said it maybe underground (nothing done about that)
7th engineer, came and he found errors and he said it was a wire that has been twisted and replaced it
guess what yep it’s still the same, if I do a speed test through the app it says my speeds are not as expected and it says the speed from BT to hub are the issue and then it logs a fault.
nobody can seem to fix this problem or if they do come up with a suggestion nothing is done about it.
bt tell me that it’s us that’s the problem but how can it be us when the engineer is finding errors constantly at the pole and not in the home and the app is saying there are issues from BT to hub
im tired of it now and don’t know what else to do
3 REPLIES 3
Message 2 of 4
Re: At a loss
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
Wow that is some number of engineer visits
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 4
Re: At a loss
This is a list of your BT Smart Hub settings and current statistics.
Product code:Smart Hub 2
Serial number:+091298+1911006890
Firmware version:v0.21.03.07094-BT
Firmware updated:Mon Oct 12 08:51:36 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,20 Hours34 Mins19 Secs
Data rate:10.924 Mbps / 58.078 Mbps
Maximum data rate:10.846 Mbps / 58.210 Mbps
Noise margin:5.8 / 3.1
Line attenuation:8.6 / 19.0
Signal attenuation:8.6 / 23.7
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:723.6 MB Uploaded / 13.0 GB Downloaded
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-HCA2MC
2.4 GHz wireless channel:Smart (Channel11)
5 GHz wireless network name:BT-HCA2MC
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:64:CC:22:34:CB:85
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 4 of 4
Re: At a loss
Also the quite line test was done yesterday when then engineer came and there was no noise on the line
