Burmey
Message 1 of 6
August update caused slow down
My broadband had been working well and had a pretty good solid connection for several weeks bar one little blip.
Since the latest update, my speeds have dropped and my noise margins increased. It happened  straight after the update. Coincidence maybe but it does seem weird.
Anu suggestions?Screenshot 2019-08-19 at 12.45.05.jpgScreenshot 2019-09-05 at 11.33.32.jpg
5 REPLIES 5
Sage
Sage
Message 2 of 6
Re: August update caused slow down
Give it a couple of weeks and it should settle again. Meantime 3Mbps and .05dB is nothing to get worked up about.
Burmey
Message 3 of 6
it was 50 a month ago though! Upload speed is pretty rubbish! But yes, I'll see what happens but why it should change after the update I don't know.
Burmey
Message 4 of 6
Well, the connection has dropped 8 times since the new update, 5 times today.  There's something not right here.
Message 5 of 6
If this has only happened since the firmware update then maybe a factory reset to ensure firmware has updated correctly may help speed and stability
recessed button on back and hold 20/30 secs until lights flash
Burmey
Message 6 of 6
Thanks I’ll give that a go when I have time ; I’ll lose all my settings and I haven’t got time to sort all that out at the moment. BT shouldn’t force updates on us if there is danger of it not installing correctly . We should be able to choose timing for when we have time to deal with mess ups
