eternity
Message 1 of 2
Auto resync after 14 days?
Hi all.
Hope someone may be able to answer my query.
I have the SmartHub 6 and since using it I've noticed thst every 14 days, the router resyncs automatically. It's happened on three occasions since I got it and I can't believe it can just be a coincidence...
Can anyone confirm this is meant to happen?
1 REPLY 1
Message 2 of 2
Re: Auto resync after 14 days?
It's not "meant" to happen but it does with certain firmware on certain cabinet chipsets.
