jmedwards
Message 1 of 3
BBC iPlayer fine on a computer (via WiFi), abysmal on Samsung SmartTV via ethernet
Does anyone have a simmilar experience and even better a solution?
I can't fathom why (and unfortunately no way of testing wirelessly from my TV).
2 REPLIES 2
Message 2 of 3
Re: BBC iPlayer fine on a computer (via WiFi), abysmal on Samsung SmartTV via ethernet
Seems odd, I have 2 Samsung smart TV's and both are fine over wireless. Have you tried updating the firmware on the TV?
UpperNthSt
Message 3 of 3
Hi
I too have a couple of Samsung Smart TVs and both wireless and wired Iplayer (even HD)work great but only after updating the firmware.
Also make sure each device has a unique internal IP on your network if your not using full DHCP (if you are using full DHCP to allocate make sure you havent 'fixed' an IP on a device, say like a laptop) to allocate IP addresses and reboot any transparent LAN switches/hubs you have on route to the TV.
Gluck
