on 17-02-2020 11h45
Hi there evryone,
If i put my hub on 5ghz wifi will i get charged extra on my Hub Bill??
Solved! Go to Solution.
on 17-02-2020 11h51
Not sure what you mean but if you mean if you use the 5GHz on your hub the answer is no.
on 17-02-2020 12h04
Yeah i did mean on the hub thanks 🙂
