sallynwa
Newbie
Message 1 of 5
BT BURIED CABLE/DUCT
Please what is the maximum clearance allowed between a buried BT cable/duct and a structure?
4 REPLIES 4
Message 2 of 5
Re: BT BURIED CABLE/DUCT
Depends what the structure is.
sallynwa
Newbie
Message 3 of 5
Building foundation
Distinguished Guru
Distinguished Guru
Message 4 of 5
What type of building?
Do you think we can get to the problem without having to play 20 questions?
Moderator
Moderator
Message 5 of 5
Hi @sallynwa welcome to forum and thanks for posting, Openreach will be able to answer this question for you. The OpenreachNetwork location webpage has more info and contact details.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
