JamiePay
Message 11 of 31
Re: BT Broadband been dropping 7+ times a day for months.
Ive looked everyware and cannot find a filter
pippincp
Sage
Message 12 of 31
Then you risk a £129 bill if it turns out to be an internal problem.
JamiePay
Message 13 of 31
Do i need to give 151 a call then?
imjolly
Message 14 of 31
yes
CJT80
Recognised Expert
Message 15 of 31
@JamiePay
You could pay £129 (if it's your internal wiring) or under £10 for a BT MF50 ADSL Microfilter.
Search on a popular "auction" site begining with the letter E.
Make sure it's a boxed one.
A few days wait saves the cash.
Ask a friend/colleague if they have a spare one?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
JamiePay
Message 16 of 31
So do i plug in my router to the test socket and what do i need to check for?
john46
Message 17 of 31
yes using the filter connect your hub to the test socket then see if the connection remains stable
JamiePay
Message 18 of 31
Right i found a filter and have just unscrewed the socket and pluged it all in, but when you asked about checking if there is a dial tone on other sockets, this is the only one i have in my home. My old master socket got cut off.
CJT80
Recognised Expert
Message 19 of 31
@JamiePay
so the socket you are connected to is the only working socket in the property?
  1. Do you have a phone you can plug into the socket? If you do.. when you are not using the internet, remove the filter, plug the phone (on its own) in and dial 17070 use the option for Quiet Line Test and see if you can hear any noise. If you hear noise, report it as a voice fault (do not mention broadband) via 151 and state you are in the test socket.  (if you have done this already, ignore this step)
  2. If there is no noise I would continue to monitor the connection, and see how it peforms.  If it's as bad, report it as a broadband fault via the helpdesk.
(Edited to improve reply)
Kind Regards
CJT80
gg30340
Message 20 of 31
@CJT80 wrote:
@JamiePay
You are allowed to say E-Bay, Amazon and any other retailer that you want. You just can not post links to them or their products.
