JasonK
Newbie
Message 1 of 6
BT Broadband not working when on the phone
Been a BT customer for couple of months.
Multple devices are connected to the Hub no problems but when the phone rings the broadband does not work.
The Hub flashes orange almost everytime when someone is on the phone. Whether it be a outgoing or incoming call.
Only using the master socket for both the phone and the Hub. Using the inbuilt filter on the socket.
If anyone could help with this issue I would greatly appreciate it. 🙂
Did not have this issue with Orange Broadband so there must be something wrong on BT's end not ours!
5 REPLIES 5
Distinguished Guru
Message 2 of 6
Re: BT Broadband not working when on the phone
Could be a faulty phone,
or a faulty filter,
or a line fault.
Can you try double-filtering the phone if you have a spare dangly filter?
If not, I'll try again 🙂
Message 3 of 6
sounds like a high resistance joint and it needs an engineer visit to resolve
ItsChip
Message 4 of 6
Can you specify your current setup?
Which Hub do you use?
Does your phone socket have the 'Openreach' symbol on it?
Do you use filters?
Is your hub connected to the master socket?
Is your phone connected to an extension socket?
    To say thanks for this post, please click the star on the left
   If not, please accept my apologies, hope I can help next time
Message 5 of 6
@Its Chip
The poster has posted he has no extensions and the phone and hub are using the same socket infinity uses a filtered faceplate and unless a self install infinity 1 service will not use filters
ItsChip
Message 6 of 6
My apologies, I missed that line in the OP. I agree with John, sounds like an engineer job.
Call BT on 151 and report the problem, they'll book an appointment for you.
