JEvans16
Message 1 of 7
BT Broadband
Hi, I'm just wondering what my options are for getting my master socket moved? It's currently in the hallway and it looks awful - it sticks a mile out of the wall; about the same width as my phone!
Ideally I'd like to have it in the living room so I can connect my TV and Xbox via ethernet for a solid connection.
I was also wondering if it'd be just as easier to buy a say 10m rj11 cable (if that's the right one - the supposed grey cable) and just run this under the carpet so I could place the router in living room but still have it connected to the master socket.
I appreciate I won't get the master socket moved during the epidemic but once it's safe to do so, I don't think I should have to pay c£130 to get something moved that looks shoddy in the first place.
Any suggestions / advice much appreciated.
6 REPLIES 6
Keith_Beddoe
Message 2 of 7
Re: BT Broadband
@JEvans16
What BT Broadband package do you have, and which BT Home Hub are you using?
imjolly
Message 3 of 7
Re: BT Broadband
do you have any extension sockets near where you want the new master.  you will not get it moved for free.  you may be far better when possible to get a local telecom engineer to do the work and far cheaper than openreach
running cable under carpet is not a good idea as often gets worn causing broadband to continually drop out
JEvans16
Message 4 of 7
Re: BT Broadband
Hi, I've got BT Fibre 1 and the Smart Hub.
Basically my WiFi on my smart tv is knackered and it'd be cheaper to buy a new TV than get it fixed as its out of warranty so I was just thinking that I'd connect it via ethernet but obviously need my hub closer.
I was wondering whether upgrading to the complete WiFi and using one of the hub discs would work ie. Place the disc near the TV and connect the TV to the disc via ethernet (from what I've read online, I think that'd work). Though I don't seem to have the option online to upgrade to WiFi complete but nothing a phone call couldn't sort.
JEvans16
Message 5 of 7
Re: BT Broadband
No, only got the one socket. Can local engineers do that? The cabling outside would need replacing as it's too short for the new location. I was under the impression that only BT/Open reach could do this but then I read somewhere that that is actually a load of rubbish.
imjolly
Message 6 of 7
Re: BT Broadband
probably easier and cheaper getting powerline adapters
JEvans16
Message 7 of 7
Re: BT Broadband
Are they reliable enough for connectivity and speed?
