Message 1 of 2
BT Business Hub 2 Alternative?
Currently have a new business esssential 910mb/s package.
They have provided a BT Business Hub 2 which I would like to avoid using.
I'm unable to get my TP Link Archer vr600 working with this new connection and have spent the day on the phone with BT going back and forth but still no joy.
Doing some reading it appears the router I'm using is not "G.Fast compatible" but struggling to find an alternative?
I've seen this but still uncertain if it's compatible and I'm aware TP-Link have a different version of the AC2800 so just confused!
Any suggestions would be great! TIA
1 REPLY 1
Message 2 of 2
Re: BT Business Hub 2 Alternative?
@ech0v1
As you are a BT Business customer, then you will need to ask on that forum,
https://business.forums.bt.com/
This is the residential forum.
