Message 11 of 32
Re: BT Capping
What is your download speed like as a comparison when connected directly to the hub instead of wireless?
Message 12 of 32
Re: BT Capping
@nugget96wrote:
I have the exact same problem! Upgraded to fibre 250 from fibre 100, no change in speeds. They sent me and engineer who showed me the line speeds of 272mb downlpad, I told him that's all well and good but my router is giving me 130/140 max wired.
So they send me another router, no difference. Now they're sending me discs as they say that will pickup my wired speed which I know it won't 😕 seen a few posts now like this, bt have a problem
What are you using to test this speed? if a pc, what are the capabilities of its network card(s),  it sounds like it could possibly be a 100Mbps card and is maxed out already if your getting 272 to the router.
Message 13 of 32
Re: BT Capping
I am using a GB ethernet interface directly connected to the Home Hub and the ethernet link is working at 1Gb/s. I have used different PCs and they are all capable of handling data transfers at GB speeds.
Message 14 of 32
Re: BT Capping
@tnjradwrote:
I am using a GB ethernet interface directly connected to the Home Hub,  Whats a GB ethernet interface?
Are you saying your network card is 1Gbps? Whats it set at under properties/ speed and duplex? What speed did you get connecting a cat5e/cat6 directly from the pc to the homehub?
Message 15 of 32
Re: BT Capping
My pc is capable of getting the speeds, used to be with virgin and it happily got over 300mb. There is an issue with the smart hub 2 which bt don't want to acknowledge
Message 16 of 32
Re: BT Capping
Have you turned off smart setup?, have you turned off 2.4ghz wifi and tried connecting to the 5ghz wifi? Are you connecting wired or wireless? Post stats from router and we could be able to help you.
Message 17 of 32
Re: BT Capping
Hi,
Both my WiFi channels are on, but I don't speed test through them I test hard wired to devices using bt wholesale speed checker. Here's my router technical log
Product code:Smart Hub 2
Serial number:+091298+2019014172
Firmware version:v0.15.00.06145-BT
Firmware updated:unknown
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:1 days,00 Hours00 Mins55 Secs
Data rate:44.021 Mbps / 272.293 Mbps
Maximum data rate:44.527 Mbps / 270.525 Mbps
Noise margin:3.3 / 3.3
Line attenuation:0.0 / 35.5
Signal attenuation:0.0 / 35.5
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:3.2 GB Uploaded / 61.8 GB Downloaded
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:Corona
2.4 GHz wireless channel:Smart (Channel11)
5 GHz wireless network name:Corona
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:18:82:8C:08:A6:49
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 18 of 32
Re: BT Capping
Unless there is a bandwidth restriction in the Home Hub which is very unlikely there is some point in the network where the data rate is capped. This is not a time of day contention issue as similar speeds are available 24/7. Somewhere in the network either in or upstream of the cabinet there is a cap/restriction applied.
Message 19 of 32
Re: BT Capping
To earlier questions the network and storage systems I use can support internal data transfer rates of 1GB/s or close to 100Mbytes/s. 140Mb/s download is way below any internal thresholds. Seeing my  line speed rate has more than doubled but the data download rate is exactly the same points to a restriction somewhere upstream. I am a retired telecoms engineer so I do understand the technology even if not familiar with the latest equipment.
Message 20 of 32
Re: BT Capping
@tnjradWhich is it? Internal transfer of 1Gb/s or close to 100Mb/s? There's one heck of a difference there. I think you mean 100 MB/s.
You really need to get your head around the following.
1GB/s (data transfer rate) = 8Gb/s (ISP speeds are quoted in bits (b/s) Megabits (Mb/s) and Gigabits (Gb/s)
