Message 21 of 29
Re: BT Chat Advisor
your download speed is set by your IP Profile which is 96.79% of your actual connection speed you actual download speed can be anything up to your IP profile
also a speedtest carried out wirelessly is not accurate
Ant3000
Message 22 of 29
Re: BT Chat Advisor
I've had to complete wired speedtests as the bt customer advisors won't progress with troubleshooting unless your using a wired connection.
Whilst "vectoring" does appear to potentially solve some of the issue of crosstalk how long will this take to roll out? And in the meantime I'm not receiving speeds quoted with the potential for further degredation
If crosstalk is a relevant factor to degredation of service and I was encouraged to sign up based on receiving maximum speeds do you think it worthwhile I attempt to "renegotiate" my costs?
Message 23 of 29
Re: BT Chat Advisor
At 70mb you are still getting a better connection on infinity 2 than many and as it is within your estimate then I would think it highly unlikely BT will negotiate anything. As your noise margin is above the norm of 6db it may still reduce giving a speed increase provided you can maintain a stable connection. It may take 3 weeks maybe longer
Ant3000
Message 24 of 29
Re: BT Chat Advisor
Based on the DSL checker on the A range of a clean line the low downstream I should expect is 69.4mbps and router stats are currently showing 68.45 mbps so I'm currently just outside the lowest range!
If the crosstalk is affecting the SNR how unlikely is it to return to 6?
Message 25 of 29
Re: BT Chat Advisor
Provided quiet line test is ok then I still think you will get a bit more speed when noise margin drops to 6db
Guru
Guru
Message 26 of 29
Re: BT Chat Advisor
Ant3000
Those figures on the BT Wholesale database are sync rates rather than throughput speed, as overheads, IP profiles configurations can be slightly different between ISPs.
As your sync rate is at 70Mbps then you are still just within the A range.
If it degrades a lot more, and the DLM doesn't slightly increase speed (which can take upto 3 weeks+), then it can investigated.
As imjolly has also said, make sure your line is okay quality wise (ie no audible noise on the line) via the quiet line test.
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Message 27 of 29
Re: BT Chat Advisor
Your router stats show 70.088
Ant3000
Message 28 of 29
Re: BT Chat Advisor
Sorry I was looking at the stats in the "connection" rather than the "help desk"
Ant3000
Message 29 of 29
Re: BT Chat Advisor
I'll keep an eye on the stats and keep my fingers crossed for the dlm.
I have called the quiet line test and all seems to be quiet during the call (although I do get some clicks initially)
