syan123
Message 21 of 39
Re: BT FTTC Cabinet - ECI
Hmm, as the HH5 is free when upgrading - I will test it out before getting a new one. But the fact is I want good strong WiFi signal all over the house and a bit more control over the router than just a couple of simple options and the HH5 from what I read doesn't supply a good ranging signal.
_______________________
Bart. K.
syan123
Message 22 of 39
forgot to ask before hehe
How long do you think it will take to finish the works?
Current Stage:
  • Links between PCP and the new cabinet have been installed today
  • From what I know fibre isn't pulled in yet to the cab
  • Power is connected to the cabinet
  • Cards (DSLAM) have been installed - 4 of them (Does it mean 256 customers?)
Bart. K.
Message 23 of 39
If that is just your cabinet being installed then it is more likely to be months than weeks
Message 24 of 39
could be from weeks to months before going live there is no set timescale
Sage
Sage
Message 25 of 39
4 cards = 256 customers served. Listen out for the fans, once they are turned on it isn't long after that the cab goes live.
chris6273
Recognised Expert
Message 26 of 39
Current Stage:
Each card (Assuming OR use the maximum density) on an ECI DSLAM serves 64 customer ports, so yes - 256 slots for customers.
It completely depends on the area and what has been done already.
It also depends on whether your cabinet is one of the first in the area being deployed - If it is then OR/BT Wholesale also have the job of installing the additional equipment in the exchange for the cabinet backhauls and may also need to install new equipment for the entire exchange's backhaul which isn't cheap and can take a while to install.
I'd say months to be honest. There can be blockages in very old ducts which can halt fibre blowing until they are cleared.etc.
___________________________________
Like this post? Give it a Star :D. If this post answers your question, please Mark it as the Accepted Solution.
RipandBurn
Message 27 of 39
Sorry to crash in!
Also have seen a new cabinet go up in the village two weeks ago.   Currently on an at best 3Mbps connection and being about 250m from the cabinet as the crow flies (so probably 400 by BT wire) and the thought of getting (gulp) poosibly 30/40 Mbps, I started to get really excited!
The BT/Openreach "coming soon" list shows Dec 14 as the date - or does that not mean being able to get the benefits this year?
Cold shower time?
Sage
Sage
Message 28 of 39
400 mts cable length will give you 25-30Mbps. Still better than 3Mbps.
Message 29 of 39
the dec 2014 is just the holding date and will probably mobe to mar 2015 nearer end of year
syan123
Message 30 of 39
BT keeps saying that the cabinet will go live for orders before Christmas.
Bart. K.
